will 4.5 run in a machine with a Decklink card?
  • will 4.5 run in a machine with a Decklink card?
    Just wondering if the new version still refuses to load if a competitor's hardware is installed?
    Q6600 Quad-Core2 [email protected], Asus P5K-E Wifi MB, 2GB DDR2-800 RAM, BFG 7900GTX OC 512MB, Edius NX PCI-E, Edius 4.52, Adobe Production Premium CS3, Windows XP Pro SP2
    Edius loads... but it doesn't use Decklink Card of course
    Edius 8.5
    Desktop: Asus X99-E WS USB3.1 - Intel i7 6800K - 32Gb RAM
    Notebook: Asus N56V - Intel i7 3630QM 2.4 GHz - 16GB RAM
      So it now loads fine at least? You don't have to disable the decklink card for Edius to launch??
        it works perfectly on my system:
        Asus P5K
        Core2Duo E6600
        GeForce 7600GT
        I leave Blackmagic Deck Control opened so I can capture and import in Edius. Blackmagic files (QuickTime or AVI) works great in Edius.
        Unfortunately we can't use it for realtime output... :(
        Edius 8.5
          Thank you! Is it the DeckLink HD card?
            No, I have a DeckLink Extreeme PCI
            Edius 8.5
