Hi,
Just downloaded the trial version of Edius 6 and have a problem with printing to tape. I am using a desktop running windows XP.
I have a Panasonic nv-gs500 DV camera. I can capture from the camera, but cannot print to tape.
The project settings I use are:
DV 720x576 50i - 16:9
I get the following error:
There is no output preset to match the project settings.
Frame size: 720x576
Frame rate: 25/1
Field order: Lower Field
Aspect Ratio: 1024x720
Video Quantization Bit Rate: 8bit
Sampling Rate: 48000Hz
I tried different device presets for the camera, but none worked.
The settings are:
Input: Generic OHCI, 720x576 50i, DV codec
Output: Generic OHCI,
Several settings (but none worked)
[DV]720x576 25 over 50i 16:9
[DV]720x576 50i 16:9
Any idea what I am doing wrong?
Frame size: 720x576
Frame rate: 25/1
The settings are:
