pocketcam to dvd telecine
  • pocketcam to dvd telecine
    Hi,
    and a second question: I have HD material from a pocket camcorder, that does 720p at 30 and 60 fps. The result should become a Pal DVD (SD, 50i). I noticed, that you can just start a Pal SD project and put the clips into the timeline, so they are converted. There are even several options for this conversion. But all have their disadvantages, and i am not yet happy with the results (ghost images, jitter with faster movements). Are there better solutions, or plugins for this, or recommended settings/guidelines?
    I use T4 Xpress for any NTSC to Pal conversion
    as long as it is installed on your Edius PC, you will be able to convert your source to Canopus HQ
      Is that Tmpeg? And does it produce any artifacts? Does it use frame-blending or Motion-adaption?
        yes, Tmpg
        it does not use frame blending, of course you will see that a pan is not as smooth because 5 frames in every 30 will need to be dropped to turn NTSC to Pal
        but I prefer the overall sharp results compared to other methods
