2 or more clips to the same audio level in one time
  • 2 or more clips to the same audio level in one time
    Is it possible to take the volume of 2 or more clips the same at a lower or higher level?
    Fred
    Hi Fred.
    If you gang the the different tracks in the audio mixer window, using the gang button at the top of the track fader this will create a sub-group. If you then go into track or automated fader movements, these tracks will move together up and down in volume, in ratio to their individual volumes.
    Hope this helps.
    Dave.
      Dear Dave, I understand what you mean, but how can i see in my clips that the audio is change to another level. When i look in the clip volume there is nothing change in the volume, only when i look in the audio mixer there is a change.
      Fred
        Fred.
        If you have used proper audio editing software like Nuendo or something similar. You would be used to the waveform changing when you do things like volume or dynamics changes. Unfortunately, Edius is not so good at this, many people have problems with the way Edius chooses to not be so helpful with waveforms. You have to do more work with your ears and not your eyes when working with Edius.
        Sorry this may not be of much help.
        Dave
          Hi Dave,
          Thanks for the information. Maybe does Edius in the future something for the audio. Otherwise i close my eyes and listen very good to the audio :-)
          Fred
            Hi Dave,
            Fred.
            I know a lot of users have asked for the audio part of Edius to be re-looked at for future updates, lets hope. My normal workflow includes exporting my locked off Edius audio, and mixing it in a Nuendo system with loads of VST DSP hardware. While this route is normal for film work, it would be a push to expect a video editor on Edius to have to do the same. If Edius was a little more like a DAW (Digital Audio Workstation) in the way it handled audio, I could see myself using it's audio features more, and staying inside Edius for all but the most complicated stuff. Right now I would easily settle for the audio waveforms being dealt with properly in Edius, as a very good move forward.
            Cheers.
            Dave.
              use the Normalize clip/clips tool and you will see the waveform change
                Hi Anton.
                I think Fred was talking about the waveform representation against volume, something that can happen on other systems. Normalizing is something that will change the inherant dynamics of the original audio file. Either way, I think it is more to do with what people may expect from the audio side of Edius, if they have used proper audio tools.
                Cheers.
                dave.
                  the Edius normalize tool changes the volume and increases or decreases the waveform at the same time
                  you can normalize the same clip a million times if you want, nothing will change other than volume according to whatever db value you dial with the mouse scroll wheel
                  I often do it 2 or 3 times to get the level I want
                  I also use the normalize tool to lower volumes
                    Hi Anton.
                    To be honest I do not use that tool in Edius as most of my audio is done externaly. It sounds like the normalize is again something that Edius does in a strange way. The stuff that I use, such as SSL or TC Electronics, will only do this process once to the audio to reach the average or peak of the file. If you are talking about doing it a few times to get your desired level, then I understand why.
                    Cheers.
                    Dave.
                      the Edius normalize tool is nothing like the Soundforge RMS normalize that applies dynamic compression on peaks to avoid distortion
                      the Edius normalize tool is a simple volume changer based on peak, it can be reset to 0 in audio properties tab at any time
                      I find it the fastest way to set volumes
                      If I do a TVC or anything else for Broadcast, I use Soundforge Normalize and Wave Hammer
                        For anyone in the VST domain on DAW's. Try out the dynamics plugins by TC and Sony on the PowerCore, for classic Neve try UAD, and for the classic SSL bus master and c200 algorithms try Duende. All of which are fantastic dynamics processors.
                        Does anyone know if Edius will pick up the above plugins and DSP's, to use inside Edius audio tracks?
                        Cheers.
                        Dave.
