Ok... So I have always had nothing but realtime editing however many streams of DVCPRO HD 720/1080. I could do color correction, transitions, 4 layers of 3d PiP, etc. The only thing I couldn't do in realtime was 3d transitions basically...
I seem to have noticed a slow down in EDIUS after the upgrade. While I have not been able to delve really deeply, the difference is enough that it is noticeable on the surface.
Examples include one track of 1080/24pa DVCPRO HD with old movie filter applied for a few seconds of the track. Just grain was added to the filter.... Lose real time. Playback stops.
Things seem slower in 720p/24pn as well.
Title Motion Pro has completely lost real time performance. I opened up an SD project that had an intro title composed in title motion pro. EDIUS choked on it. Playback stopped.
I decided to do an uninstall and a fresh install of EDIUS 4.5, and a fresh install of TitleMotion Pro.... Still having the same issues...
Any ideas that I might check out?
I should add that I did a reformat of my system drive a couple of weeks ago. If anything, though... my system is running more efficiently than before... Also didn't notice really a problem with 4.24. Had a one minute promo reel in 720p/24pn DVCPRO HD that I was cutting that worked fine. Had title motion pro and it was realtime...
EDIUS has not become completely useless, and the realtime performance hasn't gone completely down the tubes, but it has taken quite a noticeable hit.
Thanks very much,
Jason
Thanks very much,
Jason
