Using 4.5 and other apps at the same time
  • Using 4.5 and other apps at the same time
    Version 4.51 is working great on my desktop and for the most part great on my laptop as well.
    However, on the laptop, if I have another app open like my email or even task manager, when I try to switch back to Edius it takes a long time...sometimes 30+ seconds. If I check the task manager I can see Edius is hitting the CPU for about 5-10%. If I leave the computer alone for a while Edius comes back and runs fine. I even have this problem if making a title in TMPro. I close and save the title and about 30 seconds to a minute later I get Edius back.
    Is there a setting in Edius that is slowing up the application switching or is there a BIOS setting that is affecting some things with the new Edius and app switching.
    I have already completely uninstalled and reinstalled based on instructions on this forum just in case something got corrupted on the original update.
    Thanks for any help!
    How large is your buffer setting in EDIUS?
      I suspect you are out of RAM and the system is forced to use the page file, which will drastically reduce performance. Open up Task Manager and go to the Performance tab to see how much memory is being used. If the Peak Commit Charge significantly exceeds the amount of RAM in your system, the hard drive will become the bottleneck.
        I initially had it set very high at 512 but I have already reduced the buffer sized down to 128. I had done this prior to posting this question thinking it may be the culprit. It is still taking awhile to refresh the screen.
        I have my desktop set to 384 and it is working fine with the same amount of RAM.
        BTW... my laptop and desktop both have 2GB RAM.
          what is the hard disk speed result of the laptop?
            I have 2 GB Ram.
            My PF Usage is at 573MB
            Commit Charge (K) settings are as follows
            Total 821568
            Limit 4033676
            Peak 901264
            The very bottom of the task manager says.
            Processes 48 CPU Usage 8% Commit CHarge: 802M/3939M
            My desktop is showing a 907mb PF Usage and bigger numbers under the Commit Charge and it is working with lots of snap and quick program changes. Of course the FSB on the desktop is faster which may help. My desktop has a 667 FSB.
              The only Hard disk speed test that I have (that I know of) is in Scenalyzer. I ran the test in Scenalyzer it came back with a write speed of 237.6 frames per second or 7.9 times RT....this is working with DV sized frames.
              Is there a better speed test to run?
                Strange. I also have 4.5 on a notebook. Both my drives are sata.
                I have the latest chipsets drivers from intel for my note book.
                I often have a screen capture program open ftp program , brower and Paint.net.
                Work here.
                EDIUS is set to 512 buffer and I have 2 gig of ram.
                But my video card has separate 512 mb memory on board not that shared nonsense stuff which some notebook use.
                  Could it possibly be a video card issue. Since the overlay is handled a different way could there be some settings in my graphics card that are causing the screen not to refresh as quickly. After all, when I am sitting waiting for Edius to come back the CPU usage is very low meaning Edius isn't working too hard. The Hard Drive light only blinks sporadically during this time.
                  Could it be a graphics card issue?
                    If your video card is using that shared stuff it could be.
                    What is you graphic card and how much memory does it have on board?
                      Work here.
                      I have the ATI RAdeon with 256mb RAM in my laptop. I have set all the graphics card settings back to default. In the process of maximizing the Edius app from the blank desktop it has taken longer than typing this note. I started typing after I clicked on Edius in the task bar and Edius is still not back and live. Oh....there it is now...it took that long to restore to full screen. I have also tried the different overlay settings to see if they affect it in any way with no luck.
                        Yes, shared memory architecture integrated graphics are also possible culprits. That can eat up hundreds of megabytes of memory.
                        The other thing you can try is to reboot your system, and without loading anything else first, defragment your drive, and then create a permanent swap file, which will then hopefully be contiguous. There are also disk optimizers that can defragment an existing swap file -- PageDefrag is one that is free and very good at defragmenting system files.
                          What about drivers. Does your notebook manufacturer have updated drivers for your Graphics card?
                            I think I mentioned earlier that it is an ATI Radeon with 256Mb of RAM. I am pretty sure it is not that shared stuff. It is an actual card.
                            BTW....my laptop is a Dell Inspiron 9400. The hard drive is only a 5400RPM drive but it was working great on version 4.24.
                              That laptop should be fine.
