Audio question
  • Audio question
    I am running Edius 6 and my audio is consistently low.
    In my project settings do I want to have my Audio reference level set at -12db or -20db. I have it set now at -12db.
    I was under the impression that having it set a -20db would allow the audio to be even lower. Is that correct?
    those referenence levels have no effect on volume - they represent the lowest level the meter will show up on the display. so altering them will make no difference to the output
      when you select -20 and use normalize, the clip will be normalized to -20 unless you manually increase it in the normalize tool
      -12 will give you louder results after normalize
      In Edius6 I would use -6 because I often normalize monaural1, my radio Mic channel and -6db produces the correct level since Edius6 no longer supports the edius3 compatible panning mode
      in Edius5 I use -12 with Edius3 compatible panning mode
      what does Edius3 compatible panning mode mean:
      when you set a stereo channel to mono1 or mono2, the audio level is cut in half, this is too low
      when using Edius3 compatible panning mode, the audio level remains the same, this is great and speeds up the workflow in my case
      if you don't often use mono1 or mono2, then this is no big deal
        Ugh, is this so? I often use mono 1 or 2, the resulting waveform always appears to have plenty of volume. Though I must admit I find maintaining a consistent level of audio throughout a long edit difficult to judge. I must also admit being ignorant to normalisation. What should I be doing?
        Barry Weare
        BW Videofilms, Berkshire UK
        Edius 5.5, Win7 Pro 64bit, 16GB RAM, Intel Core i7 2.8GHz, NVIDIA GeForce9600GT, 5x 1TB SATA II (24/7 WD Enterprise type) with 4x in Raid1 for video, 1x for system/utilities.
          go to customize, button, timeline
          add the normalize clip tool (do not add the normalize track tool, you won't need it)
          now you need to know what level you wish to achieve, in my case, I like -6db on VU meter
          so, the green turns yellow at the -6db mark
          now select a clip that you have set to mono1 or mono2 and then click the normalize tool and roll the mouse so the value says -6db
          click ok and test
          if slightly off, click the tool again and roll the mouse to a different value
          you can say goodbye to rubberbanding in most cases
          always do one clip at a time, or you will create an uneven mess
            You're the man Anton, thanks very much.
            Barry Weare
