capturing beta sp to premiere wont work?
  • capturing beta sp to premiere wont work?
    how do i get premiere pro 2 to capture and export my beta footage?
    Are you on the right forum??
    Rusty
    I use Edius
      By installing EDIUS and using it with a Canopus sp hardware card.?
        Is this using EDIUS SP hardware?
          Maybe the original poster is using S-Video?
          PPro2 is not supported. If you can, export an uncompressed file out of PPro and bring it into Edius and play back to tape from there.
