Temporary imaginate Fix for Edius 4.51
  • Temporary imaginate Fix for Edius 4.51
    Unofficial user fix . So don't scream at any one from GV.
    I share this with you guys so you can get up and running.
    1 Open the ivp in Imaginate
    2 Add a audio file to the project. Doesn't matter what you can mute it i in Edius.
    3Save the project file with audio.
    Now go in the Edius and scrub over that IVP.
    You could discover that on some machines it won't play realtime all the way.
    solution
    select the ivp on the timeline and press shift + g you will see a green line on the ivp when it is done. realtime all day baby. That render is smart so it will follow the ivp where ever you drag it.
    SR
    Hi SR,
    This fix works fine and all in realtime!!
    Rob
    Rob
    www.volkenkunde.nl
    Edius Broadcast 4.54| 3X SP hardware 1 NX | Dual Xeon 3.2 Supermicro | Carbon coder
      Thanks for the tip, it worked for us. How did you ever figure that out?
      tdtinker
      tdtinker
      Edius 8.5
      www.actvp.com
        Persistence? :)
          yes, that works, thanks
            Hey SR, this trick doesn't work on my system, when I drag an IVP to timeline, all I see is imaginate logo, render it still gives me the logo?
              Have you removed the logo from the Imaginate project which is there as default when you start a project?
                I don't have the logo in this project, it has 3 pictures that I had pan and zoom on it.
