How export from Edius 6 to Final cut pro 7 ???? help me please ???????
  • How export from Edius 6 to Final cut pro 7 ???? help me please ???????
    hi
    Please help me
    I need to export a movie to be finished in final cut pro 7
    but i do not know which format is suitable for playing back and could be work well in FCP ??
    please give me the most and the best format that i can i use to export to FCP
    Try DVCPro or DVCPro HD.
    Jim
      DVCPro or DVCPro HD are not active in my edius 6 ????help
      hi
      thanks for answering my question but
      DVCPro or DVCPro HD they are not active so i cannot use them
      how to make them active
        Are you using a demo copy or full release. If it is a full release what are your project settings.
          Also, be sure to tick the check box for "enable conversion" in the print-to-file exporter. Once you do this, you should be able to export to anything from anything.
          Unless you're using the demo version, which is not able to export to the full compliment of codecs and formats.
