In Edius Pro 4.24 I'm trying to restore / recapture several AVIs that I deleted by accident. When I access the Restore Offline Clip dialogue, the only choice that works is Open The Clip Restoration Dialogue. Capture options are greyed out. When I open the Clip Restoration Dialogue, Start Batch Capture is greyed out and the only Restoration Methods available for each clip ar relinking a file or relinking a folder.
Why can't I capture? Is it a setting? I can successfully capture and batch capture from the capture dialogues but not from Clip Restoration. What should I check?
Thanks!
Thanks!
