Has anyone had any luck with 4.5 and the RexRT? It installs ok but the RexRt driver does not appear in the settings! Any help would be greatly appriciated! feltenvi
Edius 4.5 and RexRT
RexRT drivers are not included in 4.5....go to the Canopus site and download the drivers from your RexRT page. Install it, then restart your computer. See if it works.
I don't think RexRT is "officially" supported by Edius anymore, but some people seem to have luck with 4.24.
Try redoing the Driver Install by going into the Driver Folder and re-running Setup.exe and rebooting the system.
...AngeloCanopus/GV: DVStorm2 w/component-out board, ADVC300, Edius 4.61, ProCoder 3.05, Imaginate2
I'm currently install Edius 4.51 and looking at both DVStorm driver TXT file from both v4.51 and v4.24, both have the same 2.01h driver version for the DVStorm. I didn't check your RexRT but I'm assuming it the same too, but double check.
Okay try this if you what to; unzip Edius 4.24 in as C:\DLFiles\Edius4.24UP and ONLY install the drivers from Edius 4.24 driver folder and see if that works.
I understand unsupported... but
it's almost like this was intentionally disabled for REX RT users. I would love to take advantage of the rebranded bug fix version of Edius 4.51.
Unfortunately, if I have to go OHCI, Edius won't be my NLE of choice.
Hiro retired too soon...
Originally posted by Matt View Postit's almost like this was intentionally disabled for REX RT users. I would love to take advantage of the rebranded bug fix version of Edius 4.51.
You like your Rex, so do I. Was it working before 4.51? Just go back and it will work once again. Were you happy with Edius 4.24? Your talking about a piece of computer hardware designed in, I think 1996. 11 years in use in a computer is unheard of.(I still feel it was the best piece of hardware Canopus released).
So, please, cut em some slack.
I still have mine in my second machine. I really don't use it. Editing with
the NX and having HD output then going to the Rex is a big drop down the evolutionary scale. I am currently upgrading my second machine to
HD, but with uncompressed capabilites.
It was mentioned in the sticky that this might happen. We were lucky that it still ran, for the most part, in 4.0. Be happy you were able to use it this long.
This is why I upgraded last year to the NX. I was not happy about it, but
the writing was on the wall.Jerry
