I'm just getting into it, but it doesn't look like TM Pro is an option for title work. I hope I'm mistaken.
No TM Pro with 4.5?
If you own tmpro install it again. Then use the sp1 patch (which fixed the locked line thing among others)
Tmpro can't be included because there where packages sold cheaper without tmpro.
So if you own you have it. If not time to buy. :)Steve
Originally posted by SRsupport View PostIf you own tmpro install it again. Then use the sp1 patch (which fixed the locked line thing among others)
where is the SP 1 patch?
thanks
In the download section.Steve
It was also on the inscriber ftp in the canopus folder.Steve
