Configuring Transitions
  • Configuring Transitions
    I have a problem configuring certain transition effects, in this particular case the sphere 3D effect.
    I basically have a map in my video, and I am trying to configure the sphere transition so the little sphere would emerge from a specific point on the map, but cannot figure out how. In older editions of Edius it was possible to manually configure the starting position of this effect. Is it not possible any more?
    works fine here when using GPU transitions/Sphere (not 3D transitions/Sphere)
      Thx
      Yup, it works, thanks!
        I have just begun using Edius 5.5. Prior to this I used Rex Edit which had many explode transitions. They appear in Edius 5.5 and I am trying to figure out how in 5.5 using a GPU fly away transition in which Video A & B are in motion with a black background to insert a picture into the background changing it from a solid black to an image. In rex a whole keyframer would appear giving many options: background etc. I have not found this in Edius. Need some help
          After adding the transition, did you double click on it in the Information Palette?
            If I right click on the transition in the effect bin the properties window opens that show what the transition is, but a keyframer window that allows changing of the background or other adjustments does not open. This was pretty straight forward in rex edit. In edius I am getting a choice of transitions with no ability to make changes to movements, colors in background, or adding an image.
              As pjsssss wrote: Add the transition to the timeline, then go to the Information Palette and double click on it (left click, not right). You will have all kinds of options to configure.
              Fred D
                I got it. One more question? In the other settings tab, in the middle of the page there are some options for the background, video a, video b, matte, transparency. How do I change the background to an image rather than a matte color.
                  does your transition have a transparent background option? if yes, stick an image or video on a track below the transition
