I have a project that is 1080/24p that I just need to burn straight from the timeline to SD dvd. Problem is, the only option "burn to dvd" gives me is blu-ray. When I change the project settings to "Generic OCHI SD 24Hz 720 x 480 23.98p over 59.94i 16:9", the burn to dvd option is greyed out. If I start a new project "HQX-E1 SD NTSC 720 x 480 59.94i 16:9 (DVD)" and drop in the 24p clips, it will work, but the resulting footage looks kind of blurry when there's motion as the frames gets blended together.
I know I could use the Virtual Dub method to downconvert but don't want to add in extra steps as I don't need (or want) to mess with a menu/authoring. I just need a straight burn to dvd dub.
What project settings should I use to get this done...? Thanks!
