im told you can use the hdmi out of your video card to an hd monitor for playback. what is the advantage of going with hd spark instead for the same purpose
benefit of spark
On videocard HDMI out you will see all your desktop, in case you are working in your Edius- you will have bin window, timeline etc.
From Spark- you will see the video you are working on. Also the colore palette will be correct from Spark HDMI out. I use to have a standard TV set for SD editing that connected to my NX Express card, not to videocard output and when I am doing some color correction I can see exactly the picture and colors my customer will see.Asus P8P67, Intel i7 2600K working at 4.50 Ghz, 16Gb Kingston RAM, Windows 7 64bit, 500Gb system drive, 320Gb Data drive and 1TB RAID-0 for AV, Edius NX Express, EVGA nVidia GTX 570 2.5CB DDR5, 750w ALTEC power and some creativity...
JIm,
It is a line-scaled output in the yuv format. A signal from a video card, in some cases is pretty good, it is still not line scaled and in yuv, it is still RGB as your computer monitor is.
With Edius 6, you will be able to use that HDMI out to, in most cases, the second monitor and get a output of the program monitor overlay, but still in
RGB.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black.
Jim,
If you have Digital 8, DV or HDV, you just use the firewire input on your motherboard. If you do not have one on your motherboard, just pick up a firewire card for $30 bucks, or less, and your ready to roll.
Here is a link for a much cheaper price. I purchased my NX from them with no hassles. This is just the card (non pro card) and no software is included.
http://www.sharbor.com/products/GRVN5010019.htmlJerry
I said that is was just hardware .
You have E5 already, correct?
What is b&h for hardware only option?Jerry
So from the other thread, NX is at the end of the line, is Spark the closest to replace? I don't need 10bit, it will be a while for me to move up to that level or until 10 bit camera a cheap enough for me, I just need HDMI out to monitor and color correct, audio monitor, I read on the comparison chart, Spark doesn't have HQ hardware encoder, would that be faster than if I have a fast computer if I need to render to HQ?I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
Ok thanks, 1 more question, since Spark doesn't use hardware encoder to HQ, most of my stuff now is from CF card but once in a while I still need capturing from HDV to HQ, if I do using firewire card, are most cpu fast enough to transcode to HQ? I have a dual quad zeon 2.66.I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
