EDIUS 6 & TM Pro
  • #31
    TMP
    If I recall correctly, for those of us that upgraded from Edius 4, we needed to use the TMP disc from Edius 4 in order to run the Edius 5 version of TMP. So I'm going to assume that we are included in the Edius 6 upgrade path to TMP, correct?
    • #32
      This is great new for us TM Pro users. As a V5.5 user, it was said I still would have $299. upgrade price, even after the end of the year. If I wait until to upgrade to V6, say in June or 2011, am I going to loose the TM patch?
      Question #2, I still use Imaginate 2 and have read that I will need to change to Layout process, or something like that. Most of my IM moves are just zoom in and out, or pan across. Usually just one photo at a time. Can the Layout tool do this? Could someone show us users how it works? What are the limitations of the Layout tool, in regards to photographs?
      Bob
      PS.. I wonder why the the programmers needed to take out out ability to use IM within Edius V6?
      Originally posted by GrassValley_SW View Post
      Apologies for the delay in clarifying the position with respect to TitleMotion Pro, only it has taken a short while for us to co-ordinate a response.
      Clearly it is not acceptable to penalise people upgrading to EDIUS 6 by removing the TM Pro functionality. Equally, I think most users also now realise that there is limited scope for future development with this particular application.
      We propose, therefore, to provide a software patch, free of charge, to registered EDIUS 5 users via the normal software download section of the website. This patch will be available on the website for a limited period of time - concurrent with the EDIUS upgrade promotion at $299 which will run until the end of the year - and will enable existing users to continue to use TM Pro with EDIUS 6.
      We hope that you find this to be an agreeable solution.
      AsRock Z170 Extreme6+, I7-6700K OC to 4.7, MSI GTX 980ti, 32gig of ram, H100i cooler, 1TB WD Black for system. WD Black drives For footage, Sizes changes as needed. 2 WD Gold drives are in a Raid setup, Win-10 Pro 64bit. Edius 7.53
      2 24" HD Samsung monitors and a 43" Sony UHD TV, XBR-43X800D. 2, Panasonic DVX-200 Cameras.
      • #33
        Originally posted by Bob Nilsen View Post
        Re: Imaginate
        From other threads, I understand that the Imaginate programmers don't work at GV anymore, but I'm still perplexed by this, because surely GV still has the program source code. And I can't really see why anybody would want to remove the feature anyway. The ability to directly use the IVP file is still far better than exporting from Imaginate (as AVI). I think the export option also only allows exporting to SD, but using the IVP file allows everything to remain in HD if that's what your program setting are. This is a real loss.
        Maybe GV might go the same was as the NX card and release IVP file support at a later date? GV? Anyone?
        Intel Quad Core Extreme 3GHz/12M, 4Gb RAM, 2Tb Hot-swap (ARAID), NVIDIA GeoForce 8800 GTS, Edius Broadcast 4.61 / Edius 5.5, Procoder 3, DVDit Pro HD, Sonicfire Pro 5, Mercalli, Vitascene, Adorage. TwinPact 100, Pegasus, TMPro. VirtualDub
        • #34
          Not going to happen. GV would love to still be updating Imaginate but however complicated the code was, they cannot/do not have the ability/resources to do so.
          • #35
            You need to download the TM patch while it is posted on GV website and keep it around. Please note GV did not say (I stand corrected) the $299 price will be available indefinitely. It would be withdrawn once the NX and SP card support is made available - then you need to purchase the upgrade within the timeframe GV will announce at that time.
