Problem Re-Importing HDV
  • Problem Re-Importing HDV
    I have been archiving my finished wedding projects to tape using TS writer. The tape plays back fine in my Sony HDV VCR. I need to recapture one project so use Generic HDV - Input 1440x1080 50i 25p. Instead of capturing as one long file as I expected it has separated out into numerous clips of various lengths. Each clip finishes with 5 frames from the beginning of the following clip minus audio (for those 5 frames).
    I'm not sure what is separating the clips but feel there must be a setting somewhere to force Edius to capture continuously. Help please!
    Barry Weare
    BW Videofilms, Berkshire UK
    Edius 5.5, Win7 Pro 64bit, 16GB RAM, Intel Core i7 2.8GHz, NVIDIA GeForce9600GT, 5x 1TB SATA II (24/7 WD Enterprise type) with 4x in Raid1 for video, 1x for system/utilities.
    Try Application Settings -> Deck Settings ->Automatically Divide Files.
    Uncheck all.
      Thanks very much, I couldn't find that for looking! It pays not to panic.
      Barry Weare
