Dual Monitors for Edius question
  • Dual Monitors for Edius question
    Can anyone make some suggestions on what is a good size for dual monitors for Edius? I have a 24" BenQ at the moment for single use and find it a bit cramped, but can't find exact same part number for sale anymore so will have to buy 2 new ones. Suggestions on LCD over LED, size and make would be appreciated.
    JP
    System: Built by ON2DVD http://on2dvd.com.au
    Supermicro build X8DA3 in 743TQ-865, Dual Intel X5650 - 12 core, 24 thread , 12 GB DDR3 ECC Reg, nVidia GTX 460, WD Raptor OS + WD RE3 RAID 10 array, Dell 30" Monitor, EDIROL MA-15D speakers, Win7 Pro x64, EDIUS 6.02 & Storm 3G, Vistitle, ProCoder 3, Adobe Production Premium CS5, JVC HD101, Panny AF 102, Panny HVX202, JVC GY HM 100E, Sony NEX-5, GoPro Hero
    I have 2 x 24, which works well. I do not have room for bigger monitors.
    DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
      dual monitors
      The monitors don't need to be identical.
      I'm working on a 26" 1920*1200 as main monitor with a 19" 1280*1024 as secondary monitor.
      The 19" in big enough for the bin and the effects.
      The 26" has my video-windows and timeline.
      Marc Hens
      Edius 9.51 - Panasonic AG-AC90
      desktop: Windows 10 64 bits - Intel i9 9900K Coffee Lake - 32 GB RAM - nVIDIA Geoforce GTX1070 ti (8GB) - 2 TB M.2 SSD for video - 256GB M.2 SSD for software - 4 TB SATA for other data
      laptop: Windows 10 64 bits - Intel i7 6700 - 32 GB RAM - nVIDIA Geoforce GTX1060 - 256 GB m2 SSD + 500 GB Sata-SSD + 1 TB SATA
        Old now, but I'm using Two Sharp LL 172G-B Monitors.
        No complaints at all. Timeline on the R.H.S monitor.
        Tony
          Is the 24 big enough for the Timeline and Monitors? If so, just pickup another24 and put your bin structure and vector scope, etc in there.
            I am using two DEL 24" (1920x1200) monitors, work well for me. Main issue is to be sure your video card is a happy model that does two monitors well. I am using a KVM to allow sharing one keyboard, mouse and dual montores with two differnt machines, one is dedicated to video, and another for everything else.
            As to size, anythig 19" or larger should be fine. Using a pair of 17" would be marginal in my opinuion, but will work if you have good eyes and are not acclimitized to larger displays.
              I use one CRT and one LCD for computer display - but for correction of colours, I use Panasonic Broadcast monitor. CRT is 22" and LCD - 1280 x 1024 (20").
                Thanks everyone for the help, in the past (Liquid Edition days) I used 2 x 17" 4:3 aspect ratio monitors and spread the timeline across both, hence my thoughts on needing two monitors exactly the same (hopefully with thin bezels), but as is suggested I can keep my current 24" BenQ for timeline and previews and just get another similar sized one for bin and effects pallets, or maybe even spring for a new 24" LED and use that for Timeline and previews? :-)
                Will need to check with my system builder (I'm springing for a new Supermicro, 6 core dual Zeon 2.66Ghz, 12 GB Ram super fast thingy :-)) about the suggested GPU's ability to run dual monitors, hopefully he will be reading this?
                JP
