Layouter preset issue
  • Layouter preset issue
    I am using Edius 5.51 and seem to have a problem with saving a preset in the Layouter tool.
    I have made a complicated move using keyframes that I want to save. I can right click on the Layout tool and save this as a user preset, no problem. I can then apply this to other clips.
    Instead of that method if I use the preset save option within the layout tool then go to another clip, open the layout tool, select that saved preset, the keyframes don't show up. I have the keyframes box checked.
    Is this normal?
    yeah that is a bug.
      Is this normal?
      for Edius => yes this is "normal"
      the manual tells nothing about the difference from the two parts of the Video Layout
      in cause to the two generations who it is developed
      this is the only hint on page 385 and it tells only "for ALL clips" in future
      nothing about you can not save as Peset
      and you must go over self created "customer preset" in the effect palette
      please, excuse the "gibberish" english .... greetings from Central€urope
        Thank you both for stopping me think it was something I did that was wrong!
        Does anyone know if this better in version 6?
          it looks like this may work. setup your layout and hit OK. go back to the timeline and right click on the video layout in the info box and save as a preset
          John Sirb
          Lake Breeze Video Lorain,OH
          SYS 1: Edius 9, Vistitle 2.5, Boris Red,Neat Video, Gigabyte Z170x G5, I7 6700K 4.0Mz Skylake, G.SKILL Ripjaws X Series 8GB x2, NVIDIA QUARTO 2000
          JVC HM-100,JVC HM-700, JVC HM-600, Canon 80D
