Edius won't capture Still Frame
  • Edius won't capture Still Frame
    I don't know what could have happened, but from one day to the next Edius will not capture a still frame. Ctrl + T does nothing. The snap shot button does nothing. Remapping the keyboard short cut to a new assignment does nothing. I haven't installed anything new on the system that runs 4.03. I'm baffled. Any ideas?
    UPDATE: On a whim I installed the latest version of Quicktime. It solved the problem. I don't know why, but there it is.....
    Jared McClure
    Member
    I found I had this problem, but it was because I didn't have the clip selcted that I wanted a still from.
    Graham
    www.myvideoproblems.com
      Lucky for us it's unrelated to Quicktime!
      Select the Timeline and "Ctrl + T" = saved still.
      Select the Bin and "Ctrl + T" = new title.
      I pitty the Fool who messes with Mr. "Ctrl + T"!
      Rusty
        Jared, go to export and choose the still frame exporter. If that works, use it once, and then go back and try the shortcut.
          Thanks Pat. It was just Quicktime. I installed the update and voila, back to normal.
