Help with mp4 Output Settings/Options
  • Help with mp4 Output Settings/Options
    I need my internet video files to be in the mp4 file format.
    I shoot in 720p60 and would like to output files for web viewing at 720x405 and 900x506. Basically two smaller video windows but keeping the 16x9 ratio.
    When I look around in the export module I see h.264 listed. When I try to keep my output in square pixels it says unsupported format.
    Is mp4 for internt file use even meant to be an option with Edius 5?
    If not, has this been added to Edius 6?
    With all of the Flash assault lately, the straight mp4 file type seems like the best way to output files... That is if we can in Edius.
    Thanks for your help.
    Bassman I think you can achieve those custom frame sizes in mp4 via the QuickTime exporter use the cropping settings if needed.
    Here is a link to a tutorial by JShaw and whilst not exactly what you want it may provide insite into manipulating the QT exporter to get what you want.
    http://www.joe-shaw.co.uk/2010/04/ho...35-1-in-edius/
    Maybe Edius 6 custom projects will allow direct export.
    Regards HTH
    Dave.
    www.nakedeyedv.com
      Thanks Dave. I had a look but I think that method will result in a .mov file.
      My web design program needs an mp4 extension. Which is possible by changing the file type right above quicktime but then a different settings dialogue box appears for mp4. This dialogue box is not working well for this.
      I have a call in for tech support so I will see if I get anywhere tomorrow.
        Quicktime exporter support these file types:
        Gintaras
        Edius 8.5/ 5.51, Panasonic hc-x1, Canon 5d3, Canon 550, JVC GZ-GX1 www.gintarasmockus.lt
        i7 3770k, 8 GB RAM, Gigabyte Z77-D3H, Geforce GTX 650 2 GB, 120 GB SSD, 2Ă—1 TB HDD, Win 7 HP 64
          Thank you. Yes, the exporter supports .mp4 file types but the only 16:9 choices in the separate dialogue are your project settings. Everything else seems to be 4:3 "old" internet sizes. Plus the bitrate defaults to 64kb.?.
          If there is a different dialogue please let me know.
            Update:
            Tech support called me and gave me a way to accomplish this.
            Inside of the Quicktime Exporter, click on "Enable conversion, a list of choices appears. Choose MPEG-4 640x480. Hit Export. Then go into the "settings" dialogue and change to your desired frame size, bit rate etc...
            This makes an .mp4 video using the H.264 codec perfect for internet use.
            Hope this helps if anybody else needs this file type.
              Bossman, Thank you for this post!
              I have suffering for a long time with conversion=)
                Originally posted by Bassman View Post
                Update:
                Thats beautiful WHY so buried....can someone make a preset for that? Can I make a preset for that?
                Jdroadie
                Philly, PA
                Edius 7.53 HDSpark, I7920, GTX470 Win7 64
                  YES
                  At the bottom of the export file window where you choose the export format is a series of button, Save Preset, Import Preset and delete Preset
                  The last used presets will be shown in Recently Used
                  Select the preset from the list and Save the preset
                  Then select My Presets and import
                  Regards Barry
                    awesome
                    so simple so perfect...just a little buried..but not anymore. thank you
                    Jdroadie
                    Philly, PA
                      Hello!
                      I am searching a solution for the export in .mp4 from Edius, and this thread like have a solution...BUT!...I need a solution for make a file with high quality (.mp4) for streaming servers. The same file must be used in TV station. How I can have a valid output from a single file for these two applications? Thank you all.
                        Create 2 seperate export settings as required, save them with unique name, on next project completion choose batch export and load the 2 saved export presets, drink coffee, done :)
                        Tony D.
