We keep getting inconsistent audio monitor output with NX and edius 4 when we have three sound tracks (The final output/export is fine though). We don't have a separate sound card, but only the mobo (Asus P5W64-WS PRO) built in chip. Might a separate sound card fix our problems? Any recommended cards that works well with NX (Not too expensive... We don't need xlr and so on =)? Thanks.
Recommended sound card with NX?
Why not monitor the audio from the NX?Steve
Originally posted by SRsupport View PostWhy not monitor the audio from the NX?
Where do you plug your speakers?Steve
That's what I want to know.
You are connecting
1 speakers
2 monitor out.
How do you have them connected to the NX/expention kit?
Can you be a little more detailed?
SrSteve
Why not compare both outputs? I use an Alesis Multimix8. Built-in Plug & Play soundcard works nicely with Edius (now on topic) voiceover. I disable my onboard sound and I can fade between NX, Multimix8 sound and various decks.
I plan to pair it with the new Breinger in August.
RustyRusty Rogers | Films
