Project Setting Preset Question
  • Project Setting Preset Question
    What project setting with Edius5 would you use when shooting dvcprohd 720 30pn to P2 on a HPX170?
    Thanks...
    Mark Williams
    [email protected]
    http://vimeo.com/channels/3523
    http://www.pond5.com/artist/mark29
    Edius 8 WG, i7 6700K, Asus 170-A mobo, 16 GB Ram, System 960 Evo M.2, Video multiple 850 Evo SSDs, Shadow Rock Slim cpu cooler, On board graphics, Corsair 400c case, HD Spark, Windows 10, Panasonic GH6
    Bump....Bump..
    Mark Williams
    [email protected]
      Have you tried matching the original dimensions and frame rates in your project preset?
      I'd begin there.
      Are you going to DVD?
      Bumping on the same day as the original post may bring scorn.
        Hi Mark
        What is your main output destination/format as this will to some degree dictate the project settings you use.
        Having said that Edius has a 1280x720 29.97P setting for generic ohci hd which is square pixel and normally used for P2 HD AVC Intra-100. or you have a 960x720 29.97P over 59.94P for DVCPROHD/AVC Intra-50 P2 HD (not sure exactly how this handles your native stream re duplicating frames)
        To get an output to your monitor via Spark you may need to use one of the 1080 29.97P presets and switch back for export. (HDStorm does not have a preset for 720 29.97P I think Spark may be the same)
        Sorry not to be of more help.
        Dave.
        www.nakedeyedv.com
          Thanks guys. Project output is 1280 x 720 and is for the web. The bump... was because the shoot was today. Sorry for the bad "manners". Time was not on my side.
          Mark Williams
          [email protected]
            In that case I would use the 1280x720 29.97P OHCI preset for output, but if I needed to monitor via HDStorm I would use one of the 1080 29.97P presets and switch back to the 720 29.97P preset for final output.
            Regards
            Dave.
            www.nakedeyedv.com
