DVD audio sync
  • DVD audio sync
    When creating a DVD in Edius 5.5 (burning directly to disc) I am noticing that the audio is losing sync...It is a long DVD around one hour 20 minutes, a lot of it is music overlay so its hard to notice when the problem is beginning but around one hour I am seeing words not matching lips. I double checked the timeline all is in perfect sync. Using an HP quadcore Windows 7 machine. Any ideas?
    Are you using an amp which may have audio delay set
      Thanks for the reply but no audio amp set
        what format did you choose for audio? make sure you choose ac3 at 256kbps for best results
        do not use mpeg audio, this is set as default for Pal users and is wrong
          I am burning using the Burn to DVD function right from the timeline. Can you adjust the audio parameters such as you say doing it this way?
            yes, in the first tab, the movie tab
            http://www.videoproductions.com.au/h...vd-burner.html
