I have a finished project in SD. All the editing is laid out the way I want it.
Now I want to generate an HD720p project of the same thing. I have re-rendered all my animations to have 720p versions.
I know the process is not automatic but what I would like to do is to import the SD sequence so I have all the tracks in their positions, then replace each clip with it's 720p version. Is this possible or do I have to totally recreate the edit from scratch?
When I tried the 'Import Sequence' it gave me an error about the sequence not using the same settings.
Thanks!
Thanks!
