layout changes- how to apply to multiple clips
  • layout changes- how to apply to multiple clips
    Hi all,
    I have recently been working with an SVHS tape and it has a flicker on the bottom edge. Using layout, I can modify each clip individually, but I thought if I temporarily grouped all of the clips, I could just alter the layout once to make a global change. Not so though, it still only alters one clip. I know this must be easy but I cannot find a solution by searching. Help would be appreciated
    thanks
    Rod
    Rod Pike
    www.voxvideoproductions.co.nz
    A set of high quality paint brushes don't make you Rembrandt!
    Windows7-Edius 6.55-HDspark-VISTITLE v2.5.TMPGenc 5.vitascene v2-mercalli V2-Respeedr v1-Intel core i7 4770 8mb quad core processor-Asus Gryphon Z87 mobo- 16Gb ram-1 x samsung 256gb SSD 840 pro sata-2xWD 1tb sata caviar blue in raid 0-ASUS gtx 760 overclocked 2gb graphics card. Asus DRW 24 DVDRW DVD player-Cameras:Panasonic AC160A and AF102. and an 8kg cat who sleeps on my desk all day.
    I think that when on the timeline, on the clip where the Layout has been modified click on layout (under Information TAB), then drag and drop that onto all the other clips in one hit.
    i7 3930K, Win 10 pro 64 Bit.
    RAM 32 GB.
    ASUS P9X79-Deluxe.
    PS Thermaltake 1kW.
    Graphics Gigabyte GTX1660 OC.
      or...
      If all your clips have the same problem, you can use "Nested" sequences to make layout changes in one shot.
        Then again you can drag the corrected layouter change to the effect pallet to save as a preset then apply to the clips needed.
        EDIUS 9.5 /Win 10 x64 Dell T5600 INTEL Xeon 16 core @2.66GHz 32GB RAM /NVIDIA GEFORCE GTX 1660TI, SSD SAMSUNG 500GB PRIMARY, WD 5.5TB STORAGE, 2x WD500GB ASSETS, heroglyph 4.0, Sony AVCHD cam, Canon DSLRs.
        Sys 2: Asus ROG G75series
          hi all, thanks for all the input. solutions here as always. Cheers!
          Rod
          Rod Pike
