Edius 5.51 install problem. Help
  • Edius 5.51 install problem. Help
    Hi...
    Just tried to install the 5.51 edius update and got this error message. Any help appreciated. (I do have 5.10 installed and runs fine)
    >SetupNew\setup.cpp (138)
    PAPP:
    PVENDOR:
    PGUID:
    $14.0.0.162
    @Windows XP Service Pack 3(2600) IE 8.0.6001.18702
    What does this mean?
    Regards,
    Sheeba
    Edius 9.3, ProASUS TUF X299 Mark I LGA2066 DDR4 M.2 USB 3.1 Dual LAN X299 ATX Motherboard, Intell Core i7-7820 X Skylake-X 8-Core 3.6 GHz processor, GTX 1070, 500 GB Samsung 850 EVO SSD), 4TB WD Enterprise HD, 16 GB Ram, 2 LG DVD burners, Win10 Pro. Intensity Shuttle. Vitascene V.3. Vistitle 2.8 +
    empty the hidden temp folder and then try again
    if it fails again, you have a corrupt download, possibly caused by a download manager software
      Thanks for reply Anton.
      Where is the hidden temp folder?
      Sheeba
        In Win 7 it is Computer>name>Users>AppData>Local>Temp
          I have windows XP Pro. In my computer I have a C hard drive (for programs) and an E raid.
          Thanks pjsssss
          I'm not that computer tech savy......
          I did search for "temp" on my computer and jeez, there are lots of temp folders....so if anyone can give me a path to the correct temp folder I'd appreciate it.
          Sheeba
            "C:\Documents and Settings\Anton\Local Settings\Temp"
            you need to enable show hidden files and folders in windows explorer, tools, folder options, view
            create a shortcut on your desktop and empty the folder daily
              Thanks Anton and Pjssss....
              Success!!
              I'm not sure what made the difference because I did delete all items in the temp folder.
              BUT- the Edius 5.51 install directions said to "run the SetupManagerForEdius.exe file."
              I right-clicked that file and had menu choices of "run as.." or "open."
              I was selecting "run as...."
              and the update would not install.
              For the heck of it, I selected open...and it installed fine.
              So when the install update directions say run the file, I should "open" the file vs "run as.."?
              Appreciate the help.
              Regards,
              Sheeba
                Success!!
                Regards,
                Sheeba
                "double click the file" would be a more appropriate description, at least that is what 99% would do
