Layout Tool - Bezier Curve Adjust?
  • Layout Tool - Bezier Curve Adjust?
    I am using the Layout Tool to change the clip size over time using keyframes.
    The keyframes on the Stretch option are set for Bezier. I can't seem to link the X & Y and change the Bezier curve in one operation.
    Is this possible to link the Bezier adjustment so that both aspects change together?
    I know... the only thing you can do is move the position of the keyframes in set, more can not be changed two or more attributes (linear, bezier / link keyframes) at the same time.
    CSXD2 l For EDIUS Pro 6.5
      I think you are saying it can't be done.
      If I expand the Layout, there is a small square box under the keyframe position which has a handle. I assume that this changes the Bezier curve, is that correct?
        Yes it is correct.
          Just to make sure I understand what you said earlier.....There is no way to make changes to the bezier curve for X and Y at the same time and make the curves identical?
            As already mentioned, (X,Y) at the same time can not be... only individually.
              OK, I don't mind doing it individually, but how do I get the curve to be the same?
                Unfortunately can not make bezier duplication of the same fact to another attribute of the "Video Layout", this is one of several limitations of their operations command.
                Video Layout Currently, you can not do the following:
                - You can not do perspective function (X, Y, Z).
                - You can not do the rotating function.
                - Not applicable restoration functions (Ctrl + Z), (Ctrl + Y).
                - You can not duplicate the same movement made linear or bezier to another attribute.
                - The controls are not intuitive.
                For these reasons I prefer to use "Imaginate", is intuitive and gives you the freedom to make the movement you want, supports alpha and other functions mentioned.
