Edius Hd Overlay Problem With Supermicro Mainboard
  • Edius Hd Overlay Problem With Supermicro Mainboard
    hi to all ,
    i have edius hd , my system is dual 3,6 64bit , e7525 chipsit . supermicro X6DAL-XTG mainboard .
    quadro fx1400 pcie .
    the problem i cant see video inside edius monitor .
    i tryed all overlay option in edius setting .
    how can i fix this problem .
    thanks alot .
    Do you see video in an OHCI project setting?
      hi ,
      i just try it .
      if i open project with ohci , i can see the video in edius monitor , but if i open edius hd project , there is no picture in edius monitor .
      how can i fix this .
      thanks to GrassValley_BH .
        Oops, now that I re-read your original message and checked the Compatiblity List I find that the 6300ESB south bridge used on your motherboard is incompatible with EDIUS hardware.
        You'll need to get a motherboard without the 6300ESB south bridge. That one is too busy and does not pass data fast enough.
          thanks for this information .
          please , can you recomend me , i want new supermicro motherboard , my prossesor chipset is e7525 , xeon 3,6 64bit . and i need minimum 6 sata2 port on it for 2tb raid0 .
          i have iwill dj800 motherboard , there is no problem with overlay , i can see the video on the edius monitor .
          my problem with iwill dj800 motherboard that there is 4port sata on the mainboard . i put on it 4 hard drive segate 500 gb . i make it raid0 .
          the problem is ; any jpg file or any quick time *.mov file on the raid0 cause edius hang , and i should press the ressete botton on the pc .
          if i want to use the *.jpg file or *.mov file i should copy these files on an external hard drive .
          do you have any ideia on this problem or how can i fix it .
          i used 2 mainboard , iwill dj800 , then i change it to supermicro X6DAL-XTG .
          so , what is the good mainboard should i use and work good with edius hd .
          thanks alot .
            Personally I would try a less sophisticated Graphics card first. This has cured the overlay problem on an HD system I configured.
              The X7DAE works perfect here with 6 Sata ports and NX card
              have not tried it with HD card
                We have the X7DA3 which works great
                  if i use X7DA3 board , which slot can i put edius hd card , becuase its long card i think it will touch some thing on the board ?
                  my system now is 3,6 xeon e7525 chipset , is it compatible with X7DA3 board ? or should i change the prossesor also .
                  thanks for all .
                    You can't use EDIUS Express with these Supermicro X7DAE(8 or 3) because there are not enough PCI-e slots. Grass Valley has screwed the guy who wants to use a proper motherboard like these. You would need to use EDIUS SP with PCI-X card.
                      he is using a HD card not NX (not sure how he got the card because they only sell it as turnkey here)
                      the HD card should work fine in the 3rd slot from bottom up
                        I thought he was *confused*
                          did you restart Edius after each overlay change? This is a MUST!
                            hi to all ,
                            i Purchased edius hd card only ,,,
                            yes , every time i change the overlay setting , i close edius and open it again .
                            thanks for all
                              in that case, the problem is the graphics card or the driver, try another (older) driver
                              or wait for Edius 4.5 on 8th August, it has all new overlay technology
