SoundSoap filter questions
  • SoundSoap filter questions
    I'm experimenting with the Bias SoundSoap audio filter to remove some of the noise from ambient sound in a wedding video, and would appreciate any advice on what settings to use and how to understand the various options. I have both indoor and outdoor footage to work on and the outdoor stuff includes toasts done without a PA system at a location near a busy freeway.
    So far it seems like a low level of noise reduction with most of the options turned on produces acceptable results, but I'm curious to learn more about all this...
    Just experiment :)
    Did you come by the Edius glitch yet where audio is behind?
      What glitch is that? Is it something where the audio is consistently behind by a fixed amount, or drifts off over time?
        Kevin,
        StormDave is refering to the constant 3-4 frame lag imposed by SoundSoap. Wierd, but easily fixed.
        If it's background noise I have to contend with, I have best results by isolating an area on the timeline with in-out points. Open Soundsoap dialog. Loop playback (Ctrl+Space) Then use "Learn Noise" button.
        Results are generally accptable. Voices can be muddled, so watch out!
        Render and remove,
        Rusty
        Anybody tried the "Pro" version of SoundSoap?
          I'm looking closely now at an HDV clip with the SoundSoap filter on it and can't see an obvious sync problem for the audio. Is this something you can see on the timeline or only after rendering? Also, is it possible this is mainly happening for those running Edius on Macs, or it is also turning up on standard PCs? (No Mac-PC debate intended, just wondering.)
          P.S. I've separated my audio tracks from my video for this project, so I wonder if maybe that's helping avoid the SoundSoap glitch. I'll test further for that.
            The waveform will look the same, but the audio out will lag 3-4 frames.
            Look at an area with a camera flash/click... you'll see.
            Rusty
              Check out the SoundSoap demonstration on the BIAS website, it gives you a good idea of how to get started:
              Learn more about Auto-Tune, the music industry standard for pitch correction and vocal effects. Shop and learn about the best plug-ins for pitch correction, vocal effects, voice processing, and noise reduction. Auto-Tune Pro, Auto-Tune Artist, Auto-Tune EFX+, Auto-Tune Access, Harmony Engine, Mic Mod and more.
              Download the update to V2.1 from the BIAS website while you are at it, that will also get you the standalone version of Soundsoap. Then export a WAV file from Edius, process that using the standalone SoundSoap to clean it up, and finally bring it back into Edius to replace the original sound track. This will allow you to avoid the sync issue.
                the delay caused by soundsoap is 3.5 frames
                after fine tuning soundsoap, export the section needed to wav
                place the wav on empty audio track below and then move it to left 3 or 4 frames until the waveform lines up to your liking, then delete the original audio by clicking the A delete button on top of timeline
                  It's not 3.5 seconds! It's fraction of a second, two or three frames.
                    sorry, I typed seconds instead of frames by mistake, the screenshot explained it correct
