Photographer stills a problem
  • Photographer stills a problem
    I have stills that are jpeg 4288X2848 aspect ratio is 1.000
    Most of the stills are sideways and I need to rotate them to the correct
    prospective. I tried 3d pnp to rotate the pix but when I scaled the pix to 100% it looked awful. Is there a soloution or a work around for this?
    I have Edius 4.5
    Many thanks
    Lauri
    Using Edius 6
    quickest way is to rotate them before bringing into Edius
    Even MS windows picture viewer can rotate failing that
    download ivew32 from irfanview.com this does lossless rotations and is freeware
      ... and sometimes 4288X2848 resolutions can give you problem (black frame). Resize it to around 2500x...
      Asus P5WDH Deluxe w/E6600 - 4GB Corsair - 8800GTS - 1TB & 1.5TB (2x750GB RAID 0) - Antec P180 + Trio 650W - XP Pro w/sp3 - NX PCIe w/Expansion Card - Edius 5.51
      Asus P6T i7 920 @3.6 - 12GB Corsair Dominator - GTX275 - 1.5TB & 3TB (2x1.5TB RAID 0) for Video - Antec P183 + Corsair HX-750W - Win7 - Edius 6.07 - Firecoder Blu - PC3.05.91 - BDR-203 - TMW5 & TAW5
      Asus P6T i7 930 - 12GB Corsair - GTX260 - 1TB & 1TB WD Black for Video - Antec P183 + TPQ-850W - Win7 - Edius 6.07 w/HD Spark - BDR-205
        there should not be a need, a simple adjustment in layouter should take care of it
          Will it work in 3DPIP Anton ?
            no, because the minute you scale a large res still in 3D PIP you lose quality
            remember once you fixed the layout on one still, you can drag layout from one image to any or all others in one hit and fix them all at the same time
              What adjustment? I'm confused.... Are you talking about rotation or
              making the pixels smaller?
              Using Edius 6
                I was responding to tuyle about eliminating black edges
