Edius Timeline Protected Sequence in Project
  • Edius Timeline Protected Sequence in Project
    Is it possible to protect a sequence timeline of a edius project. So the other can'nt see how much track are used in the sequence & which effects are used........
    Please state your purpose. EDIUS is an editing software, not a software for copy protection ... if I understand your intention.
      I don't think so and that would not be a normal feature for an NLE imho.
      I would be a waste of engineering time if you ask me.
        yes most NLE's have this feature - its called PRINT TO FILE in Edius
          LOL ..... you are right. :)
            Dear Tingsern... I know it very well that edius is fo editing only... I asked this question to protect my ow project so any body can'nt know whati have done in my project, how I m using the transition & filter effect.... nothing else... iI think this is the forum where anybody ask the question... if u have any idea or concept pleae share otherwise thanks & pls. be quiet...
              Add the edited sequence to the bin; create new sequence in timeline; drag sequence from bin to new timeline sequence. Is this what you mean?
              EDIUS WG 10.34.10112 VisTitle 2.960 Windows 10 Pro 21H2
              Asus ROG Strix X570F AMD Ryzen 9 5900X 12 core 4.30 GHz 32GB DDR4 3600MHz RTX 2060 Super 8GB
              NVMe SSD 500GB system drive NVMe SSD 2TB work drive 6 x 4TB IronWolf Pro in RAID5 storage
              DeckLink Mini Monitor 4K into JVC DT-V24L1
                similiar to that but in this case if we double click on the sequence time line it will open new sequence with detailed clips & effects... I want to protect this..... similiar to that we can lock the clips on the timeline.....
