audio sync issues in file print mode
  • audio sync issues in file print mode
    firstime user here. my project is finished and it has alot of lip syncing to music. on the timeline it plays back to the end no problem. perfect. on the print to harddisc it loses sync around the middle of a 4 minute song and is out 10-20 frames by the end. it runs perfect up till about the middle and then it gradually loses it. any ideas. i have tried different formats to export in in file print. no luck yet. i am trying to get this to DVD. the problem seems to be getting the timeline to print without losing sync.
    Did you use ochi with output to a video monitor to sync or was it a canopus hardware card?
      If the timeline plays perfectly, I'd guess it may be the player, not the file, causing the problem.
      What filetypes are you trying to play back? .avi, .m2t, .dv, .mov?
      Can you bring the output file back to the timeline and play it? How does it play there?
      Rusty
