Improved PowerPoint to Edius
    what about quality?
    the output quality of the trial version was terrible, graphics looked like mice nibbled them
      It depends on the original Powerpoint slides. I found that some people give me pictures in Powerpoint that were originally 240x320 pixels (JPEG) and expect me to create wonders from there. So beware of that.
      For normal wordings - it is okay. I haven't tested the trial version. No idea if it so bad.
        Hi Dave, try it, it works
        create a PP, one slide is enough and add an item into each of the four courners
        now change page setup to 38.1cm x 28.575cm and save as bmp or tif or png
        add the file to an Edius 1440x1080 project and be surprised
        Hi Anton
        I finally got around to playing with this and YES it works and at 96dpi when you check back in Photoshop.
        The bit that I cannot get my head around is that a new Photoshop page set up at 1440x1080 reports the bigger size 50.8 x 38.1 and at only 72dpi.
        I guess its not a good week to give up the Southern Comfort <GRIN>
        DD
