Edius external timeline monitor
  • Edius external timeline monitor
    I want to monitor an EDIUS 16x9 video stream to see it on 4:3 external monitor without distorsion to the video.
    Can this be done? With what equipment? I can get an output from an ADVC110 to a 4:3 tv monitor but the video is too tall.
    You could adjust the TV settings to Letterbox to have a 16x9 view, or adjust the TV to have pan & scan it will be a 4x3 crop then.
    Not sure if the ADVC unit can be adjusted as I think it already outputs 16x9 video (WYSIWYG), your TV might not be set-up right at the moment.
    If you change your project settings in Edius from 16x9 to 4x3 is the picture on your TV correct ?
    If the answer is yes then it's time to tinker in the TV menu options :)
