I recently finished a DV project on Edius Broadcast, but when I printed to tape (DV) the first few frames were lost. I reprinted it and the same thing happened. What is the best way to insert a black "pre-roll" at the beginning of the project to avoid this problem ?
Beginner's question
You can futz with deck preroll, but you have the best solution already. I tend to stick 10 sec. of black at the beginning of every project. If a tape is going to have a problem, it's usually at the beginning or end.
RustyRusty Rogers | Films
Originally posted by witchdoctor View PostI recently finished a DV project on Edius Broadcast, but when I printed to tape (DV) the first few frames were lost. I reprinted it and the same thing happened. What is the best way to insert a black "pre-roll" at the beginning of the project to avoid this problem ?
also, set outpoint around 10 sec after project endsAnton Strauss
