To convert a file with Procoder 2 ... problem.
  • To convert a file with Procoder 2 ... problem.
    Hi, on Internet I have just downloaded some file, I think they are divx even if I see .avi file in the extension. I cannot charge them on Edius 4 Timeìline, I get a error. Therefore I have conterted them with Procoder 2 Wizard. I have created .avi canopus file. But when I charge them on Edius 4 timeline I don't see any image, I listen the voice only but do not see any images. I thought there was a codec problem, therefore I have transfered these files to a different PC with every codecs (DivX pack) but when I click on the file I don't see any image again. Why I have this problem?
    CPU: Intel i9 7940X
    SSD Drive:
    (C) 512GB Samsung 960 EVO PCIe M.2 NVMe (Windows 10)
    (D) 2TB Samsung SSD 850 EVO 2TB SATA III 6Gbit/s (for video exporting)
    (E) 1TB Samsung 960 EVO PCIe M.2 NVMe (for video editing)​​
    Are you sure there is video in the original file? Maybe it is just audio only?
      Did you install the standard DivX codec from DivX.com or did you install a "pack" from somewhere?
        I have seen those files many times before converting them. Therefore the original files are ok. after converting I see a black screen with the voice.
        CPU: Intel i9 7940X
        SSD Drive:
          Yes I have installed DivX codec from DivX.com. I see may films with differnet codecs but I don't see those converted files. I see the black screen only.
          CPU: Intel i9 7940X
          SSD Drive:
            I'm sorry! I have just solved my problem installing DivX codec pack again.
            CPU: Intel i9 7940X
            SSD Drive:
