freezing and stuttering of display window
  • freezing and stuttering of display window
    hello.
    I am using Edius 3.62
    DVSTORM RT K12-pc -112
    system is i5, windows xp, with ATI/AMD video card (all in wonder pro), directx 9.0c
    currently i am feeding the Edius from my VCR with the RCA type jacks to the front of the stormbay.
    Problem: i can only get one frame at a time to display in the window on the timeline, it will only update to whatever the active frame is by clickin off the program or moving a window around in the program. I have it set up with dual display for the edit/playback. If i click into the playback window then back into the edit side..it will also update.
    hope you can help!
    I would call tech support but I would guess that the Storm may not be compatible with your new motherboard. Also could be a graphic driver problem.
