HD export question
  • HD export question
    If using an HD timeline, when exporting, what is the difference with using Canopus HQ (fine) and Canopus HQ 1920x1080 16:9? I would think that since I'm using an HD timeline that the Canopus HQ fine is 1920x1080 16:9. Are they the same presets?
    David
    DMS Films, New York
    Desktop - Edius 5.5 / Intel i7 975 Quad Core 3.33GHz / 12GB DDR3 1333MHz / Nvidia GeForce GTX-275 / Vis Title 1.1 / FireCoder-Blu / (2) 27" LCDs / JVC DT-V24L1U (24" 1080p) / Windows Vista 64 - www.EditHD.com
    The Export is 1920x1080 16:9 the same as your project, the (Fine etc) only refers to the compression and hence file size, from my point of view I cannot tell the difference, but use "Fine" and larger files just in case!
    Regards Barry
      Hi Barry,
      I also cannot tell the difference so I've been using the "Fine" preset. Thanks for the reply.
      Cheers
      David
      DMS Films, New York
