proDad Mercalli
  • proDad Mercalli
    Usually my stuff is very steady except this time and I try out Mercalli and this filter is freaking awsome, take away all of the micro jitter and look like tripod quality, thank you GV for including proDAD. (-:
    you're right: BIG yahoo!! for this filter!!
    Paranova Films
    Cali - Colombia
    http://www.paranovafilms.com/
      I have been using this a lot lately for some run n gun footage that I shot. I was simply amazed at how well it works. Yes a big thanks to GV for giving this to us!
      Tom Koveleskie - Director/Producer/Editor
      Quarter Town Films - Independent Feature and Documentary Films.
      Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
        Khoi thanks for the post. I'm going to give it a try.
        On a somewhat related note... I finally took some time and learned how to use Neat Video. There are several ways to use it but I have it installed as a plug-in for Virtual Dub. To quote Khoi's original post, Neat Video is also "freaking awesome." I would actually consider it a game-changer. What is does is to remove grain. I use canon 7Ds as well as other videocameras. Sometimes I have to gain-up with the EX1s which is something you don't want to do. NV remove ALL of the grain. It's amazing. The image may become a little soft but add a sharpness filter and you're good to go. I wish I had this years ago.
        Cheers
        (I don't work for NV)
        David
        DMS Films, New York
        Desktop - Edius 5.5 / Intel i7 975 Quad Core 3.33GHz / 12GB DDR3 1333MHz / Nvidia GeForce GTX-275 / Vis Title 1.1 / FireCoder-Blu / (2) 27" LCDs / JVC DT-V24L1U (24" 1080p) / Windows Vista 64 - www.EditHD.com
          The prodad filter is great. I was able to save a critical shot containing some micro movement thru my tripod. I could not determine any image degradation in the final product.
          Mark Williams
          [email protected]
          http://vimeo.com/channels/3523
          http://www.pond5.com/artist/mark29
          Edius 8 WG, i7 6700K, Asus 170-A mobo, 16 GB Ram, System 960 Evo M.2, Video multiple 850 Evo SSDs, Shadow Rock Slim cpu cooler, On board graphics, Corsair 400c case, HD Spark, Windows 10, Panasonic GH6
            Hi Mark,
            Just a suggestion, but try it and then view on a large screen and witness the difference. When I use Mercalli I ALWAYS add a "sharpen" filter to the shot. It does compensate for the slight blowup which Mercalli affects. For HD I use a sharpen setting of 21, and for SD I use a setting of 12. It's just up to your taste, but on my 14 ft. HD screen these settings make the Mercalli'd shot the exact same in resolution as the surrounding shots.
            Have fun -
            Alan
            Alan J. Levi
            Director
              I think I have the same experience as Alan and therefore need to agree that on a really large screen the softer image mercali produces is visible, while performing a great job otherwise.
              Lucky for us Edius is RT and a sharpen filter is a good and fast solution.
                Thanks for the tip. I will try it out and view on a larger screen.
                Mark Williams
                [email protected]
                  Yes it is a little softer, but that is normal and a little sharpness will fix it but I'm sure my client wouldn't know that it is softer but they would for sure see the micro jitter if I didn't use the filter. (-:
                    Khoi Pham - I think you'll agree, a Happy client is a repeat client. Give 'em both: a steady picture and a sharp picture. They'll love it and come back for more!
                    Best,
                    Alan
                    Alan J. Levi
                    Director
                      Best,
                      Alan
                      Oh yeah, no disagreement here. (-:
                        Anyone tried the New Blue stabilizer?
                          Guy's i cant believed this
                          AVCHD file with mercalli applied no rendring Edius is too much..............
                          my fellow edius user with all the noise adobe is making about mercury engine my cpu is still clocking 80-90 with 3 layers based on my system and they want you to buy videocards GTX285 upward. as you can see in my spec i owned GTX280 but i figure how to used mercury engine with my card,but with Edius only 50-65 same file.their is proverb that says empty barrel make the loudest noise and good PR before the software is release everyone is dying get one but i love encore and photoshop and AE.it Edius all the way forever for now who Knows!
                          Window7, 64bit,Edius6.03,5.51,HDStorm, VisTitle,AMD Phenom11X4 Quadcore Asus CrossHair Motherboard,8Gigs of Ram,1TbCdrives,3Tb Videodrives SoundBlasterX-fi
                          http://vimeo.com/channels/sunflow
                          www.sunflows.com
                          http://www.sunflowphoto.com/
