hmmmm...hmmm....maybe, eventually I understood the question not correct, in cause to my fractal english....
tune down the volume ==> with what tune down
Audiomixer / or fad in / or fade out / or ruberband ??
@ Anton
application settings, application, set to linear and not log
this above setting have imho only a optical consequence ==> to the form, where the (same level curve) as waveform display on the timeline
this above setting have imho no consequence ==> to the level-curve himself
CentralEurope is correct - rubber-band fades are always linear in EDIUS, regardless of how the level-points are displayed (log or %).
The result is exactly the same. If you want to achieve a non-linear adjustment, you'l have to add more level points, or use the Audio Mixer to write level-points for the fade.
__________________
-- Brandon
Hi
I read a lot of questions from "Location: seavideo"... who ever this location is..
But i missing some answer from you, in cause to questions from user, they spend her time to clearing your problem....
example:
CentralEurope queried:
greetings from CentralEurope
