timeline Marker point stop place
  • timeline Marker point stop place
    When I cut and delete..c and delete .. can the timeline .. marker line stop at the delete point
    seavideo
    Try using N or M instead of C
      I try N and M
      I try N and M
      But No response
      What is this Key for
      seavideo
        You really need to take some time and step back and read the manual.
        First place the cursor wherever you want a cut & delete. Do NOT place the cursor on a cut point that is already there (such as hitting C). N will cut and delete everything to the left of that point in the clip and M will do the same to the right of the cursor.
          Thanks pjsssss
          Thanks pjsssss
          I will test it out
          seavideo
