Problem With FX Transitions In Edius 5.5
  • Problem With FX Transitions In Edius 5.5
    Hi
    I have just switched to Edius 5.5 from Edius 5.1 and there is a problem with the FX transitions which was not in Edius 5.1
    I have attached some pictures of the problem
    In Edius 5.1 you will see the transition is perfect but the same transition in Edius 5.5 has a border as if one of the video frames is shrinking
    I have been using Edius 5.1 for some time and imported a project into Edius 5.5 made in Edius 5.1 and this problem is not there I can add this transition and it works OK but on a new project there is this border
    This problem is on all the FX transitions
    I have exported a movie with transitions and this problem can be seen when played back on a TV
    Pictures
    Edius 5.1 ( OK )
    Edius 5.5 ( Border )
    Go into your project settings and adjust the overscan to 0 %
      Hi
      Thank you for your reply
      Yes this has fixed the problem
      regards
      Chris
        change this to 0% on your project presets and you will not have to keep adjusting it on each project
          I have now changed all my project presets
          Thank you
          Chris
