At the risk of being boring, I'd like to ask again the situation with the AE plugin for Edius.
I've just tested After Effects CS3 with the plugin, it works fine, but still we have the problem that you cannot switch between AE and Edius.
Edius will not open until you fully close AE.
This was not the case with earlier versions of the plug.
If you remove the plug from AE, you can happily switch, so it is a plugin problem.
Maybe this is not important to many users, but pro and broadcast users utilise After Effects for all their compositing needs. Some will respond with, Boris Red etc etc, but this is no answer to the situation.
Grass Valley appear to be interested in presenting Edius as a "pro" software solution, and continued failure to address simple issues such as plugins and, dare I say it VST are not helping to forge a serious link with professional users.
I'm sure this post will result in a couple of glib remarks about, " use another software" etc etc, but I'd like someone to say, yes there is a problem and yes they'll be fixed with 4.5.
I find it really odd that Edius comes with Sound Soap that will not work correctly, VST support that does not work correctly and the AE/Lightwave/Photoshop plugin that does not work correctly. It's rather like buying a car only to be told that the windscreen wipers only work when it's not raining.
I still think Edius works well and 4.5 looks like a great step forward, but please, is it not possible to sort out these tedious faults once and forever? it really is no fun switching software off and starting it up 35 times a day, then removing audio glitches caused by VST errors.
Paul
Paul
