Edius Shortcut Help
  • Edius Shortcut Help
    Can I do this in Edius
    Edius Question
    What is the shortcut for this few .. action
    Selecting the current video clip .. from timeline
    Creating title .. short cut ..on current frame
    when video put in insert how to ask edius only cut the 2v and not the 1va\
    because edius cut the both
    seavideo
    which track do you want the title to be on? T1, VA1, V2 etc etc
    Edius only cuts the selected clip at cursor position when C on keyboard is pressed
      let me see if i understand...
      that would b CTRL>T
      try blocking 1VA track
      Paranova Films
      Cali - Colombia
      http://www.paranovafilms.com/
        Let me add a quick caveat on CTRL T as a shortcut. It you have last clicked on the timeline and use this shortcut, you will get a still frame added to the Bin. If you last clicked in the Bin then the shortcut will bring up your default Titler.
          THanks
          THanks all of you
          Is there any key to select the current .. other then use mouse to click the clips on the time line
          seavideo
            I am not sure I understand your question, but A and S moves your cursor to the next cut point.
              If you are talking about layers Try using the up and down arrow key, when you see the track that has your clip you want to cut on it selected just hit the C key.
                I will test it out
                seavideo
                  add ALT before this action and this select clips... not only layers
                  Paranova Films
                  Cali - Colombia
                    How to add alt
                    Is it Alt First then press C
                    seavideo
                      Usually these combos are pressed at the same time.
                        Control, Alt and Shift are modifier keys.
                        You hold down the modifier key(s), then push and release the other key, then release the modifier key(s)
                        For example, for Control-C, I would...
                        Push and hold the Control key
                        Press the C key
                        Release the C key
                        Release the Control key
                        For Control-Alt-C I would...
                        Push and hold both the Control key and Alt key
                        Press the C key
                        Release the C key
                        Release the Control and Alt keys
                          That ok.. thanks
                          seavideo
                            How to add alt
                            ALT>ARROW KEY to select the clip you want: ALT>UP ARROW KEY to select the clip aboeve and again to select the above clip and again ans again... ALT>LEFT ARROW KEY to select the clip at the left... and so on
                            Paranova Films
                            Cali - Colombia
                              Thanks .. Get tips
                              seavideo
