White Soft Elips Border Advice
  • White Soft Elips Border Advice
    OK now I've tried these so far ;
    * Region filter with all combinations ... (Block Colour, Soft Focus)
    * 3DPIP soft border and a white color matte under the main video clip.
    They all sucked due to bad interaction between footage itself and filters. For example I must type "% 100" for soft border in region, otherwise the elips border looks so amateur and simple. However, when I just do it, this time whites mix with inside. What I try to say is the overall brightness of video increases. I just can't keep whites out.
    On the other hand, 3DPIP blackens the footage slightly when I enable soft border. I use a white matte under it, but no change. it still affects brightness of my video badly.
    All I want is a simple soft elips border with no effect inside at all. should work just for outside.
    (Meanwhile ; border darkening in old movie filter also blackens the clip. Look carefully, you'll see what I'm tellin.)
    Just make a .bmp mask in photoshop and use the Alpha mask filter, works really good for me.
      I will.... If only nobody would come with any better idea.... I already thought it before. thanks.
        Rammstein lyrics in your sig?
        Eh
          circle wipe transition works good, you can hold it in any position with the same start and end keyframe value
          you place the transition on the keyer track and stretch it to the width of the clip
          you can change the shape of the circle
            nice idea anton, but it will prevent me to use any other keyers such as 3DPIP.
              Eh
              :=) yea buddy
                not at all, use layout
                  Or make a new sequence with that clip.
