I am running Vistitle 1.1.0.3 on Windows XP Pro with Edius 5.5 - no problems, everything works as it should.
On Win 7 Pro with Edius 5.5 an error occurs when exiting Vistitle back to the Edius timeline - a dialog box which simply says 'Error' appears. Closing the dialog box returns to the Edius timeline and the Vistitle track appears to play fine.
When double-clicking on the Vistitle track to edit the title, the 'Error' dialog appears again, but carries on to Vistitle when the dialog is closed. Then the 'Error' dialog appears again on exit!
As far as I can tell, everything is ok with the titles created in Vistitle - they play and render on the timeline fine. I haven't done anything too complicated yet though.
I am currently editing an HD 1920x1080 50i project. The same problem occurs when starting a new project from scratch.
The only nuisance is the 'Error' dialog box - this doesn't occur on the Win XP/Edius 5.5 installation.
I have reinstalled vistitle, but no change. The only other option is to reinstall Edius and Vistitle again and see if that helps.
The Win7/Edius 5.5 installation is pretty fresh - only about 2 weeks: Edius 5.0 was installed followed by updates 5.1, 5.12 and 5.5. Vistitle 1.1.0.2 followed by 1.1.0.3 was installed last. There is very little else installed on the machine and no other Edius plug-ins. TMPro is not installed on the Win7 machine (it is on XP).
As far as I know Vistitle is compatible with Win 7?? And its running fine on XP with Edius 5.5.
I figure it must be something to do with my installation, Win 7, Edius 5.5 or a combination of the above.
Has anyone come across the 'Error' dialog with Vistitle?
Thanks,
Mark
Thanks,
Mark
