I have couple clips on the time line (1VA), on the middle clip after set the cursor to the point i want, hit "N" trim in point it deleted the trim and should move the clip next to the previous clip (no gap), but it did not. I don't know why. It's ok with other project. Please help
Ripple help - delete the gap
Asus P5WDH Deluxe w/E6600 - 4GB Corsair - 8800GTS - 1TB & 1.5TB (2x750GB RAID 0) - Antec P180 + Trio 650W - XP Pro w/sp3 - NX PCIe w/Expansion Card - Edius 5.51
Asus P6T i7 920 @3.6 - 12GB Corsair Dominator - GTX275 - 1.5TB & 3TB (2x1.5TB RAID 0) for Video - Antec P183 + Corsair HX-750W - Win7 - Edius 6.07 - Firecoder Blu - PC3.05.91 - BDR-203 - TMW5 & TAW5
Asus P6T i7 930 - 12GB Corsair - GTX260 - 1TB & 1TB WD Black for Video - Antec P183 + TPQ-850W - Win7 - Edius 6.07 w/HD Spark - BDR-205Tags: None
Yes, both Sync mode and Ripple.Asus P5WDH Deluxe w/E6600 - 4GB Corsair - 8800GTS - 1TB & 1.5TB (2x750GB RAID 0) - Antec P180 + Trio 650W - XP Pro w/sp3 - NX PCIe w/Expansion Card - Edius 5.51
Originally posted by pjsssss View PostWhat version of Edius? Zoom to 1 frame mode and see if there are any clip leftovers that are stoping the ripple.
pjsssss: I'm running 4.24
weird thing - with a new Sequence, the Ripple did work. (not on the old sequence)Asus P5WDH Deluxe w/E6600 - 4GB Corsair - 8800GTS - 1TB & 1.5TB (2x750GB RAID 0) - Antec P180 + Trio 650W - XP Pro w/sp3 - NX PCIe w/Expansion Card - Edius 5.51
the way I work is with ripple always off and sync mode on in most cases
Alt+N will automatically close the gap in front of the trim point
Alt+M will automatically close the gap at rear of the trim point
Backspace key will delete gap in front of a selected clip or clipsAnton Strauss
anton: thanks !
I won't need ripple any more. Alt+N & Alt+M will doAsus P5WDH Deluxe w/E6600 - 4GB Corsair - 8800GTS - 1TB & 1.5TB (2x750GB RAID 0) - Antec P180 + Trio 650W - XP Pro w/sp3 - NX PCIe w/Expansion Card - Edius 5.51
