Edius 5.x removal
  • Edius 5.x removal
    Good Evening/Day
    I am using the 5.12 version of this fantastic piece of software, and i am trying to uninstall it and install the new 5.5 version because of the support for Win 7 x64. Although everything seems to have been correctly and completely uninstalled...no luck !!!
    Something remains in the registry, i have searched everywhere to find a removal tool or utility, or something like that...but it came to nothing !!!
    So the new 5,5 can not be installed because a message comes up : this software has already expired...
    Any ideas? (other than reformating the hard drive from scratch...)???
    Thanks in advance, and excuse my poor English !!!
    Computer Details
    Gigabyte Z490 Gaming X
    Core i7 10700K @3.8GHz (8 Cores 16 Threads)
    32GB DDR4 (2*[email protected] Mhz Corsair)
    1*500 GB NVME EVO 970 plus(O.S and programs)
    2*1TB SSD Samsung EVO 870 Raid 0 for Editing
    1 Sata Dvd-R
    Nvidia GTX 1060 OC 6GB Ram 192Bit
    2 LG IPS235v-BN Led 23"
    Windows 10 Professional x64
    Intensity Pro
    Edius Workgroup 9.55.7761
    Vistititle 2.9.0.1
    Once you go Mac you may come back!!
    Once you use FCP, you always need to render
    Thats why i switch to Edius !!!
    First of all you should not have tried to uninstall 5.12. If you check the readme on the 5.5 upgrade it says that it has to install over 5.1x.
    Software expired usually means that the HASP driver needs to be installed. Try putting your dongle in a different USB slot.
    So if need be, you might have to reinstall to at least 5.1 and then apply the 5.5 upgrade.
      this is another partition where the installed version is trial. So if i install it from the begining, or just upgrade, the problem remains the same.
      As far as i know the standard uninstall procedure is not enough. There must be something "more" that i dont know...and this is exactly the problem.
      If you for example install any version of Edius, and then you want to uninstall and install some other version, you will see the same message (i hope not) but i think it is so !!!
      As you understand there is no dongle to install with the trial version.
      The dongle is for the 5.12 that i have purchased.
      Thanks for your response
      Computer Details
      1 Sata Dvd-R
      Intensity Pro
      Vistititle 2.9.0.1
        Use the commercial version with the dongle. One you have removed the dongle or used the trial for the first time the countdown begins. If you have used up your 30 days your our of luck.
        The trail is designed for 30 days so if you get that the message that it is expired well...you get the idea
        More information can be found here:
          I was always under the impression that you can sort of never upgrade a trail version, regardless of the manufacturer with a commercial upgrade ?!
            Correct . I was addressing the "EDIUS is expired message.
            The Op's post is a non-issue.
